Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
    Default R33 GTST 4 door 400bhp, Pretty good spec. Everything avaliable.
    Wish this would sell whole as it is a really nice car with a great spec and all the parts are top quality parts, someone obviously spent a lot of money putting this car together, I have a shit load of receipts showing that a lot of the parts were bought brand new not too long ago.
    I have a dyno printout to prove that the car made 400bhp/425lbsft
    RB25DET with HKS 256 cams fitted with HKS cam gears and also an uprated timing belt. It also has a Cosworth metal headgasket fitted. I also think it may have a forged bottom but I am still looking into this but I think it is very possible. The engine runs as sweet as a nut and starts perfect hot or cold with no smoke or strange noises.
    I will sell the long block with inlet manifold and exhaust manifolds still fitted.
    €Sold.
    RB25 Gearbox, will sell ready for a conversion with Box, Shifter, Prop, Shifter and it also has a Nismo slave cylinder that will go with it. Box shifts lovely with no noises or anything else.
    €Sold.
    RB25 Power FC with commander these seem damn hard to find: €Sold
    Splitfire coilpacks: €Sold
    Denso 550cc injectors: €350 for the set
    FMIC with all pipe work (May fit R32/R34 aswell): €SOLD
    Greddy TD06-17C Turbo, car drove fantastic on this turbo, very little lag and pulled like a train, turbo should be good for 400+ which is again proved by the printouts I have: €Sold
    OS Giken twin plate clutch, will obviously come complete with lightweight flywheel, in good condtion bites well but is quite nice to use: €Sold.
    Sard FPR: €Sold
    Z32 AFM with plug: €Sold
    HKS BOV: €60
    Apexi air filter: €50
    Oil catch can: €25
    Apexi AVC-R black version in really good condition: €Sold
    BEE*R rev limiter: €SOLD
    Engine damper: €SOLD
    Cusco front and rear strut braces: €SOLD
    De-Cat pipe: €Sold
    S/S Downpipe: €60
    Zgien Cat back system in very good condition,: €120
    Nismo 2 way diff in casing, locks up lovely but isin't clunky at all, I still have to confirm ratio: €Sold
    Tein coilovers, the track ones with adjustable height and spring pre-load, not cheap Superstreets!, all in extremely good condition no leaks or bangs: €SOLD
    Front adjustable tension rods: €60
    DW rear camber arms, will fit S14/S15: €SOLD
    DW total HICAS removal kit: €Sold
    5 stud rear hubs for 5 stud conversion, perfect condtion €50
    Front brakes in good condition: €SOLD
    Complete rear twin pot/disc rear brake set up with all internal drum parts and handbrake cables so the whole kit to convert your S-body to the superior Skyline rear brake/handbrake set-up: €200
    Nardi (I think) steering wheel with boss: €SOLD
    Carbon fibre bonnet, Non-vented in very good condition, with bonnet pins fitted: €SOLD
    R33 4 door shell with full interior, everything on the outside except bonnet, irish reg (currently waiting on log book to come), very clean shell, few marks here and there but nothing bad and with front rear and side Aero kit on it
    €Sold
    Probably have a few other bits which I will put up if I think of them, obviously has other standard bits and pieces on it. It is a complete car so if there is anything you want just ask.
    The car is located in Doneraile, North Cork, collection is preferred but delivery can also be arranged.
    http://r32life.blogspot.com/
    di Member pepsterx's Avatar
    Mayo
    Can you please trow up few pictures of the kit and a price please, front and rear bumpers and skirts and thanx
    Quote Originally Posted by pepsterx View Post
    Was thinking of leaving it with the shell but will PM you some pics anyway.
    Jul 2010
    Meath
    I have to say probably the most detailed breaking thread ever! Would that 2 way diff suit my R34 GT?
    Quote Originally Posted by pole drift View Post
    It would deffo fit it I would say but are the R34s like the S15 do they get the speed signal from the diff?
    Jul 2010
    Meath
    Quote Originally Posted by driftescort View Post
    I'm not sure, ill have to check
    No worries, let me know.
    Cork
    RB25DET with HKS 256 cams fitted with HKS cam gears and also an uprated timing belt. It also has a Cosworth metal headgasket fitted. I also think it may have a forged bottom but I am still looking into this but I think it is very possible. The engine runs as sweet as a nut and starts perfect hot or cold with no smoke or strange noises. The car is still in one piece at the mo so if some one is quick they could actually drive the car.
    €xxxx
    Deposit paid
    Quote Originally Posted by Cooldrft View Post
    I'll take the engine billy ,just need to do a compression test
    No worries James, Give me a text when you want to call and we can do a compression test on it before I take it out.
    West Limerick
    Whats your number?
