Toyota corolla Levin ae86 it came from japan fitted with a 4age 20valve silver top from an ae101
spec as follows
1985
189000 kilometres
later front (87)
vertex bumpers an side skirts
charge speed bonnet
aero front wings
cby arches
rota grids 15x8et0 an 15x9 et0
new bc coilovers
trd 2 way diff
uprated clutch
uprated flywheel
hydro handbrake ( has original h brake also)
apexi air an fuel controller
earls oil cooler an filter relocation
aftermarket trumpets
6 point dash dodger cage
slim line electric fans
4 branch manifold
5 zigen manifold back with shotgun style tail pipes (may be cut down or replaced with a jap back box not sure on them)
omp deep dish steering wheel
aftermarket gear knob
omoni water temp gauge
also has a vac gauge
quick shifter
sony double din with Bluetooth an aux
front strut brace
aftermarket silicone ht leads
new battery
never been welded
very tidy car
came in with no rear seats or rear plastics there all ther now apart from 2 pieces in the boot
Sadly car needs an engine.
I was for converting it to a 1jz.
I have 90% of the stuff there to do the conversion.
But i am no longer going ahead with it.
So either buy car and put back in a 4age engine or you can buy car and carry on with what i was doing.
I have all the parts i had removed sitting here.
Nothing is needed for car except another engine.
Or if you wanted to fix the old engine its here. It dropped two valves.
Bottom end is good.
Asking price is for everything.
That including the 1jz engine and manual box and the original 4age engine and gear box etc from the car.
Please no time wasters.
Car is cheaper with out the 1jz engine conversion.
It is advertised for sale else where separately.
