Putting the feelers out on this as it looks like I will need a few pound to get me to the end of University and also I wouldn't mind another R32, maybe.
Imported by myself through JDMDistro last year and apart from being driven to be registered it has never been on the road since. I looked for a while for the right car and this one suited me perfectly, really clean car but not so mint you would be afraid to drift it, good spec to start with, everything works including the tilt and slide sunroof!
1998 Toyota JZX100 MKII, VRT paid and registered in Ireland.
Converted to manual in Japan, fantastic job apart from the auto dash clocks you would have no idea it was ever an auto.
Lots of nice little features such as auto headlights, air purifier system and the A/C is icy cold. Everything works.
The shell is really clean, no rust to speak of, the rear bumper aero needs to be fixed up and repainted but apart from that and maybe a clean up of the headlights it is really good. A few little marks and scratches as you would expect from a car this age that has been used.
Good healthy 1JZ VVTi, sounds spot on. Still running stock boost.
Just had a brand new set of Grade 8 Iridium plugs fitted.
Power FC
Blitz Nur Spec Exhaust system
Lightweight engine pullies
Uprated clutch and lightweight flywheel
BRAND NEW Tein SuperDrift coilovers just fitted with custom 18/12 spring rates installed
Cusco front upper adjustable camber arms
Cusco front and rear strut braces
2 way diff, very tight, locks up a charm
Dished steering wheel
Traum gearknob
Garson D.A.D. seat covers, Much VIP!
Defi Boost Gauge
Vertex Aero front, side and rear
I am sure there is more that I am forgetting and I will add anything I remember.
Located in Cork.
€11,500 may consider P/X depending on what it is.
