Results 1 to 8 of 8
    MEATH
    Default R32 fitment question
    Front 18x8.5 et 32
    Rear 18x9.5 et 35
    Will they work on stock body
    Don't mind coilovers and arms just want to know about if arches will take them
    SuperFortress
    You'll probably want to roll the edge up so they dont skim the tyres. The back might be a bit of a tight fit if you don't roll the arch out a bit
    You'll want spacers at the front to clear the calipers, you should be fine at the back.
    Depends how low you're planning on going and camber
    di Member thetangerine's Avatar
    Oct 2012
    My Volk Rays where the same width front and back wit a et of 32 all round nd fitted perfect. 245 tyres caught a small bit on the back wit 4 on board but wit ure et ya would prob get away wit it I'd say. Hope dis helps
    MEATH
    Quote Originally Posted by thetangerine View Post
    Pretty much sums It up dude! Was hoping that it was the case, can play around with rubber width anyway. Any pics there by te way, can't remember the colour of your car, silver is it?
    @Matt, appreciate the response and point taken on height, will need to roll that horrible tyre killer lip for sure though
    SuperFortress
    No problem. I have 18x9.5 et40 on the back of my R32 and with it lowered there was no chance of survival for tyres without some rolling so I can only assume it would be worse with et35
    MEATH
    Quote Originally Posted by Hachi View Post
    What width tyre dude, the backs?
    SuperFortress
    235/40/r18
    MEATH
    235/40/r18
    Appreciate that dude, thought as much.
    Solved the issue tonight by selling them on-
    So now this is what the next possibility is
    18x9.75 et 20 all round....
    Thoughts?
