Need help in replacing old wheel studs as the prevous owner put the wrong wheel nuts on the studs so they have to be all replaced what the easiest way to do thing with out ripping the hole suspension apart
[SIGPIC][/SIGPIC]
it's not the worst job in the world if you have somewhere dry to do it this weather.
Literally pull the caliper and discs all off and you have access to the hub. Put an old nut on the end of the stud and hammer it out of the splines.
here's a how to with pics just so you know what your at
http://forums.nicoclub.com/how-to-ch...d-t381913.html
My S14 Dori Project: http://www.driftireland.com/forum/sh...ad.php?t=10638
Thanks rory
[SIGPIC][/SIGPIC]
Use a nut again to pull through the new one.
Give the hub splines a good clean & then a shot of grease before you pull in the new one. Be sure your splines from both sides are aligning properly or you could wreck the ones in the hub.
You Only Live Once
