Results 1 to 10 of 16
    May 2010
    Exclamation rb25det power lost -smoke and oil in exhaust
    hi all, 'ive got a slight problem with my skyline rb25 turbo, car was driven and abused from time to time for number of months without a hassle , recently turbo was gone so was fully rebuilt with rebore internals,new stronger and balanced shaft and seals, new engine oil was put in the car as well,after fitting turbo went for test run and all was perfect (boost is setup to 1 bar) after 20 miles started smoke, losing bit power on high revs and spilling oil thru exhaust , lost nearly 3l of oil in few minutes ,is this possible that turbo is gone again? all hoses were fitted correctly and checked before test run ,compression wasn't done yet, any ideas?please help -thanks
    di Member pepsterx's Avatar
    Mayo
    Is the engine missing as well or just smoking ??
    Cork
    Is the car mapped to run 1bar of boost ?
    Did you fit a fit a banjo bolt with a 3mm hole for the oil feed to turbo?
    Did you prime the turbo with oil before starting engine ?
    The turbo seal is leaking, either it's damaged or there's pressure building up from the oil not flowing out of the turbo.
    Check there's no kink on the turbo oil return pipe.
    Also check the cam breather pipes aren't blocked.
    MEATH
    Quote Originally Posted by Hositos1 View Post
    Compression test it before your told what it could be. may save a lot of time and effort
    di Member Driftma's Avatar
    Dungarvan,Co.Waterford
    Why did the turbo fail the last time?
    di Member shaneS14's Avatar
    cracked piston ring land, compression test it
    May 2010
    thanks for advices- all will be checked tomorrow, first thing in the morning will do compression test and then will see, cheers, btw engine runs as normal doesnt sound like cylinder is gone but all will be confirmed asap,
    So many times have people assumed their turbo was blown and it turned out to be broken piston. Compression check it and see.
    Quote Originally Posted by Bradley_Motorworks View Post
    yes i did but i did a compression test first
    May 2010
    its solved more likely, its turbo -shaft wasnt balanced at all or was done incorrectly + seals were broken- turbo sent back under warranty ,
Tags for this Thread
