Will R33 GTS-t rear calipers fit onto a R32 GTS-T ?
Iv got S13 on the back of my carSo looking to put back on the calipers that should be there, will i need any brackets or mountings if the R33 fit a R32 ?
Or do they just bolt straight on?
what peppy said, stright fit, had that on s13, so thats just in reverse
straight fit, they are essentially the same anyway bar teh material used to make them, making the 33 ones lighter
Really depends on what the cowboy put on your car? is it 5 stud still? has it solid or vented disks?, will you still need a handbrake or are you only going to run a hydro?
