Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 65
  1. #21
    Jan 2012
    Cork like !!
    front brakes are on cossie 283mm disc and mondeo caliper.
    at the moment im doing brake lines, its a great help to have the proper brake flaring tool. makes perfects flares first time every time
    and some pics of the body panels fitted back. iain did the panels for me as my attempt was desparate.
    video is being uploaded now so will stick it up later
  2. #22
    Jan 2012
    Cork like !!
    so here is where im at now.
    handbrake fitted.
    must say huge thanks to Don Giles who got me sorted for the power steering ECU on friday morning
    he has it all pre made now so its a plug and play job. just give it power.
    vince made up a new A-Frame kit and we mounted it to the car. it worked out perfect but i need to add a rear anti roll bar to stop the nose picking up.
    interior for now
    finished engine and all pipe work
    then over to the local garage to dig out some tyres
    loaded up for watergrasshill on saturday.
    so got to watergrasshill and had a few teething problems but got out and tested as best i could.
    i had a wrapped disc at the front so the brake judder was pretty bad.
    i had 1 coilpack give up so she ran on only 3 cylinders.
    then i had the hydraulic handbrake which would not work so need to bleed it out proper.
    then a pipe off the cooling system came off so i called it a night.
    but the main thing is i now know what i need to do before retrostock
    some pics out on track
  3. #23
    Member A.O'Neill's Avatar
    Oct 2011
    cork like
    Looking good lad,that has got to be the coolest wand iv ever seen!
  4. #24
    di Member Mongey's Avatar
    May 2010
    savage idea!! im loving this car
  5. #25
    Jan 2012
    Cork like !!
    thanks lads
    this is up to date now.
    well Retrostock has come and gone and what an awesome day it was.
    i was flat out for the week before retrostock getting it ready and painted so never did an update.
    so i'll fill ye in on where it's at now
    so first up was a change of axle as i wanted to run a rear anti roll bar and my previous axle had no mount points for them.
    so axle out new axle built with strength added to the spring hangers, a-frame brackets made, caliper brackets welded on.
    next up was the most important job that was making a proper bulkhead and tunnel.
    so vince welded in a complete new bit .
    then it was time to make an exhaust. so bought a lenght of 63mm pipe
    then vince made a sweet oil catch tank.
    and finally got out in mondello here are a few pics of it on track.
    at mondello i had a fair few problems.
    to start with i went out for the grip laps to make sure everything was ok but was only get 0.2bar boost pressure but after 4 laps i had that sorted and was set at 1bar.
    this was class as the power was great and i was fairly excited at this stage.
    so out for the first drift laps and after half a lap the thing was back running on 3 cylinders
    so changed coils, plugs, injectors and none fixed it.
    got a multimeter from dermot kyne and had 12v at all the coils so was completely stumped as to what was wrong.
    so i decided it had enough power with 3 cylinders to get back out drifting.
    so had a few laps with some nice drifts and then down the straight the radiator burst so thats when i called it a day.
    there is a video of it bursting on my facebook page if ye want to see it.
    so i have a few changes i want to make before i get out next but the first thing is to get this engine running correctly
  6. #26
    cork
    cool build, serious amount of work gone into it. what sort of engine was the one you were going to use initially?
  7. #27
    di Member K series steve's Avatar
    Jun 2012
    ovens,co.cork
    i love it!!!!some built man,crazy work gone in there,fair play to you!!
  8. #28
    Senior Member martycturbo's Avatar
    Nov 2010
    donegal
    great project,, some good work ans smart thinking gone into this from what i can see,, will be even better when you have all the teething probs sorted,, then you can enjoy it!!!
  9. #29
    i like cake
    Dec 2009
    nice one keeneth teathing problems accur might be something completly out of the blue in your case the coils easy fix. seen vids of ye even the car on 3 cyl was going well! struggling but well! hope to see you the next time on full tilt
  10. #30
    Jan 2012
    Cork like !!
    cheers lads.
    the engine i was originally using was a 1600 ford x-flow. about 120bhp
    hopefully once i get some issues sorted i'll be able to give it plenty of abuse.
    could someone tell me is a screamer pipe of any advantage as i like the sound of it but no idea is it worth doing??
Tags for this Thread
