Results 1 to 5 of 5
    Default Xenons for skyline?Problems?
    What are the best Xenons to get and which make,
    Heard something off a fella who does xenons in my mates cars if you get the wrong set there have been problems with ecus if a bulb blows. My mate one the wipers kept comming on and had to buy a new ecu however that was a passat but can afford to go buy a new HKS FCONIS and map again if something goes wrong.
    Anyone know more or have a set in.
    R33 Gtst 98
    Quote Originally Posted by MrSkyline View Post
    R33 Gtst 98
    wats a bulb bolwing got to do with wipers comming on and blowing ecu's that fella is talking out his hole 2 u do fit alot of these and never once did i hear anything like that
    di Member Romo's Avatar
    Wicklow
    x2 what Ian said.... Just dont get a cheap ebay set an you'll be grand
    xnenons use a huge voltage so if one blows it could cause a spike and in turn blow the ecu! but the chances are low on something like a skyline!
    passats use can bus wiring n all that shiz so chances are much higher!
    Quote Originally Posted by benhachi View Post
    u can also buy the ones that work on the can bus line like said above buy a good set and u be fine no ebay crap, iv them fiited 2 a 07 golf that also run can bus had the buld blow on me and never had a bother with blowing ecu's r the wipers etc
